Go for standard, then cut the mangkuk that hold spring below. Adjust to lower depend your satisfaction and then weld it back.
Make sure you get really good welder coz if you gonna use GAS Shock, it might to end the shock damage on the spot.
bro7 wat brand u using ,,,? my GAB still soft lah..i wan find hard like rock one but dun tell me welding 4 besi to ganti abs lah ,,,haha
Toda got adjustable, Fightex it called. http://todaracingusa.com/category?id=15?id=15
thanks bro...Go for standard, then cut the mangkuk that hold spring below. Adjust to lower depend your satisfaction and then weld it back.
really lah, my previos abs also mod like that. that why i need to replace it. when fall down into pothole like dont have any abs. very bad. so what brand suitable? if sport abs (short one) what brand and how much usually? and then what about SA series Gab? really need it before raya. if can cheaper lah. i got very small budget la..
