Need advice - 4gp2p 1.6 SOHC
eze191
Hi guys,
Need some advice on somemore mods for my ride.
Current mods:
Changed my gbox from auto to manual, drop in K&N, afc neo, 1.8 intakes, mivec extractor. (upgraded in sequence)
In the pipeline:
Afr, bigger injectors (4g93) 240cc right?.....
Am not considering tc or sc as this is my daily ride. Any feedback is appreciated. Only dynoed after installing afc (whp : std 98, after neo is 108) the ever elusive ponnies.....:banghead:
Not sure whats my a/f ratio. Dont have the stoichmeter leh... Are u saying that i should only consider afr and upgraded injectors only when i am certain about my a/f ratio?
Thinking of running high cams for this engine is it advisable?
more air + more fuel = more power
air intake increase (larger TB), fuel delivery also must increase... since u got afc neo to compensate that, ok lor... larger injectors are only necessary when ur current injectors doesnt supply enough fuel...
if u planning onto highcams as well, upgrade injectors shouldnt be a downside... u should benefit from it.... make sure u retune everything using ur afc neo on dyno tune....
