Just collected the car. when turn on the AC, airbag and OD off light keep on flashing. Just wondering what's wrong with it and if there is any solution. Wanna know before sending to SA cuz I don't trust the very much. Thanks.
Just collected the car. when turn on the AC, airbag, ABS and Hold off light keep on flashing. Just wondering what's wrong with it and if there is any solution. Wanna know before sending to SA cuz I don't trust the very much. Thanks.
supposedly you have to check the car before taking it home...
but, past is past... just go back to the sale center you bought them.... if lucky you can push for a replacement... if not, just go direct to SC to let the fix it
I fixed already. Using the old trick by unplugging the battery. Less than 2 minutes to get it done (15 seconds delay before put back). Looks like very less technical people around. Thanks for viewing.
easy only send back to the SC then tell what the problem then wait awhile they will fix for u... ur can still got warranty... dun void it if ur pocket is not thick enough..
