Myvi gearbox yrv problem
rawther
Hi,there
I have been experiencing a new problem.USING A YRV 1.3 engine which is transplant to Myvi 1.3.
ATF,NEED TO BE CHANGED At 75,000km,now the reading just at 73099km.
WHEN DRIVING,PUT D4 ..my speedometer show 1st gear and stuck with it.
When put D3,D2 work fines ...but sometimes it blinks at the speedometer and need to restart it.
What I was frequently seen is at the speedometer the meter start move slow ..late 5 or 6 seconds even after I press the gas pedal.
Then,when stopping the car or slowing the car, the speedometer jump auto gear from 3rd to 1st gear ...
What cause this problem, and my gear lever is quite loose and I feel little hash from moving from P to D/2/L ...and also can feel a slight little jerk when moving the gear lever.
U can try cleaning all connector to the gb and adjust the cable linkage properly.
some called it multifunction switch.it can be adjusted either via the cable or the switch itself to properly tell the ecu or tcu what gear u r selecting on the lever.
i am talking in general and not specific to your model.happen before to me on a different car,it confuse what gear am i selecting and the gear indicator kept blinking.
I already checked ...even changed new atf bro ...
This all started happen,when I smelt some "hangit" smell from passenger left side .. :(
