my amp hot hot lah~
sotplugDESIGNER
my amp so hot when i put the high volume for few minutes,so i planning 2 DIY 1 or 2 fan to let it cool down....but dummy in DIY,kekeke :blink: :blink: :blink:
so any sifu can teach me?how 2 join all those wire?(i wan fan wif on/off switch 1,thz) :) :) :)
Erm , sotplug , in the first place , in my newbie opinion , its unhealthy to stack an amp on top of the other as heat cant disipate properly la bro.Thats what i heard and feel , but not sure whether correct.Maybe some sifu can clarify.
Hie,
As yohannes said, not to put and stack those amps together. Put them far far from each other to cool down. If problem presist then have to add fan if you like. :)
To add a fan, get a PC fan. Most PC fans rated 12V 0.1A and it will cost you RM3 - RM5. The fan comes in with socket, cut away the socket and left two wires to the fan. Tap one to the ground and the other one to the remote. Addvantages of tapping to the remote; won't draw a single power from the live current, when engine off fan also off.
Just my opinion, correct me if i am wrong. :)
As yohannes and ken12292703 said, and i'm
gonna say it agian.. DUN STACK THEM. the amp
cover also act as somesort of heat sink to decipate
the heat generated from the amp.
where u put the amp ar ? in trunk or under seat ?
maybe u can pull a 1" hose to direct ur aircond to blow them..
kakaka... just a stupid idea.
Anothign thins is that how are you runnign your amps? Many shops that install amps like urs dunno abotu proper wiring etc... Possibly you are running your amp at lower than recommended loads...
Also, looks liek u r using 16 gauge power cables.. hehehe
I think don't need to add aditional fan lorr, just saparate the amps it will be ok liao. If your amps really needs a fan, it will have a built in fan manufactured liao. :) Just my opinion.
i oso tot b4 of separate them...but wat 2 do,no place mah... (atos):( :( :(
i put it under the seat,got 3 amp,a bigger 1 oledi 1 seat,then these 2 small amp hav 2 put 2gether.... pc fan can meh??? dunhav sifu here teaching me 2 install fan wif on/off switch??? :blink: :blink: :blink:
neway,thz 4 u guys' replies ;)
16 gauge power cables ok ah???or bad stuff???y u laughing??? :blink:
wei..i think you btter relocate the amp...
why not you try to relocate them at the rear boot...
relocate it at the rear seat....do you get what i mean?
and 16 gauge wire for amp is too thin...
the electric flow is not good....that is why you encounter problem with overheat and blink blink on the lights..
u noe i'm damn poor mah :P wanna relocate mayb need 2 buy extra cable... :( the cheapest way 4 now is install a fan 1st... :P tat's y i'm asking tat any1 noe how 2 install a fan in a car???? :blink:
"where u put the amp ar ? in trunk or under seat ?
kakaka... just a stupid idea."
good idea~ try it 1st,c got improve onot... :rolleyes:
i only got one amp so i only put it under my passenger seat..
if you have few amps..then you should have put at your boot....mount the amp on the rear seat?get the idea?
Hi sotplugDESIGNER,
first of all, why u need so many amp? (just curious) maybe u can sell both amp and get a better one... 4 channel?
Just another idea, its to mount the amp at the back seat :P
or underneat ur passenger seat.....
i noe wat u r trying 2 say,i oso think b4 putting amp bhind the seat+in the root,but really not enough space since woofer "eat" so many place,if put amp summore then habis lah,no need 2 fetch thing :D
Originally posted by tykoh@Oct 13 2004, 18:21
Hi sotplugDESIGNER,
coz i buy whole set from frens,he giv me all the amp so i put lah :P (tat time no money,so neva think of sell tat 2 amp n buy a single 4 channel :D ) now the ice in my car like tis ,a single 4 channel running double woofer(still can run summore rite?) a cheap cheao 2 channel amp (yellow) running original 4 speakers,then the xplod 2 channel running 2 mid :)
Hie,
Another opinion, why not you screw both of that amps at the back of your woofer box? This is what i am running on now. I screw a amp at the back of the woofer box to safe some space. :) Just my opinion.
