>> Motorola L6 <<
>> Motorola L6 <<
adamshahm
Narrower and wider than the size of a credit card (86 x 54 mm), the SLVR L6 measures 113 x 49 x 10.9 mm, remarkably thinner than the L7 (114 x 49 x 11.5 mm), and the thinnest Motorola handset to date.
https://www.zerotohundred.com/forums/attachments/86600
Manufactured from a hybrid glass-filled body to add stability and rigidity, the SLVR L6 is durable enough to withstand the wear and tear of everyday use that an all-plastic body would be too fragile for.
Prominently displaying a scratch-resistant 65K-color LCD screen at 128 x 160 px in resolution, the front also features Menu, Send, Power / End, and Left and Right soft keys surrounding a 5-way directional keypad.
In order to achieve L6's ultra-thin profile, a conventional numeric keypad could not have been used due to the thickness of the keys. However instead of an electro-luminescent strip used to make the L7's keypad (in one piece), the L6's keys are each made from a cut metal material (each individual key).
Turned around, the back of the L6 integrates a VGA camera, capable of snapping photos at a mediocre 640 x 480 px. However rather than hardened glass used to protect the L7's camera lens, the L6 has a plastic cover to avoid any accidental scratches.
On the left, a Smart Key lets users quickly access likely actions to follow (such as select when a menu item is highlighted), while a dedicated Camera Key along the right gives consumers quick access for impromptu moments. Also along the right, a charging port doubles as the accessory outlet.
The L6 uses cost-saving materials to bring down the price, and compared to the L7, changes are noticeable. Slight differences between the external finish, LCD screen, flush keypad, lens cover, and side key coating are not low-quality, but mediocre to the L7 when placed side by side.
Out of the box, the Motorola L6 comes with a Standard 820 mAh Li-Ion Battery, A/C Charger, and User Manual.
Price - RM 450.00
Condition - Tip Top
Color - Black
Contact num - 019-389 3081 / 017-265 6175
Adams
:phone:
its almost a new set but still we called it 2nd hand cz i've used that phone only for 1 week...now, it was in box....
