Morning sickness
zackdihaw
Hi guys...hope u guys r happy with ur altezzas. well....im not. things r not good lately. every morning since the last few day my altz just wong start right. at start ups, the engine will shoot up to 2000rpm n dip low...goes up n down a for a few secs and just dies away....with a struggle...I usually just drive away after a few mins, but the engine usually dies every time i slow down. malu ooo...n dangerous too....almost got whacked from behind the other day! It gets better after driving a few kilos. never happen in the afternoon, nite...just mornings...especially when it rained the nite b4. heppened a few month ago, but i cleaned the trtl body n cured it. my mechanic tells me it might be the MAF sensor, O2 sensor, earth wire (i changed the battery terminals a few weeks ago) or something that has to do with air n temp...any ideas?
Bro,
It happened to me too when I changed my battery..
The problem resolved after retuning my AFC Neo..
Mine is just stock Auto RS200...dont think i hv any AFCs....cant figure out why it only occur in the mornings....hmmm...but anyway, thanks bro.
send it to Vision or Trial to get a dianostics check, save you loads of time and Cash in the end guessing around. My guess its an electronic problem....just my 2 cents worth....
who is your mechanic?
yeah better go to trial or vision or dori..
personally i dont think its a major issue...and i dont think its the O2 sensor
for this kind of problem it will be either the throttle body or MAF or ECU.
Try resetting the ECU. It works everytime for me. When restarting engine, do not press accelerator...just let the engine run for 10-15 mins by itself..
Bro i encountered the same prob as well. Thank god the problems gone!!
U can call me if u need help... 012-3093118.
Will try to walk u through it...
thanks 4 all the advice....n ill call mr.viper. I tried going to trial but couldnt figure out the location. anybody can help out uploading a map...?
it didnt happen this morning...but in the afternoon when it started to rain...the rpm dropped low and the engine rattled a bit, but fortunately didnt stop. i think its somekind of a virus....cant stand the rain.
Here is the location map for u....
http://www.dromoz.com/directory/place/?id=7233&p=Taman+Sungai+Besi
http://www.dromoz.com/directory/request/?id=586&p=Taman+Sungai+Besi
It is in Taman Sg Besi which is just beside the Besraya Toll plaza of Salak South New Village.
Hopes this helps...
