Mod Apexi filter into 1.5 carb
nicteh
Hi, all sifu out there. Just need your opinion n suggestion as well.
Well, im just fix in Apexi dual funnel air filter into my wira 1.5 carb engine. Im wondering about this few questions:
1. Lenght: would it be ideal if the air ram connect from carb UNTILL the behind of battery? or no need(just short, coz i heard the air more fast)?
2. Is that possible to put on heat shield? where to fix it? how it function?
3. WHere to get the small filter(is that call breather?) what brand n place.
4. Got 2 rubber hose which sucks the air after i take off original air filter cover, 1 is from engine cover another 1 is from carb. so, which mean i have to fixing 2 breather?
5. After i fix it, i can heard my engine timing not same like last time, it sound like human breath. breath up then down...is that normal? is that i havent fix the breather? or need any tuning?
Thanks!!! :D
oh.. fix already? air ram dun need mod liaw... just use as it is.
2. heat shield... can custom make.. depends on mech.
3. Yes.. the small filter is also known as breather.. can get from most accessories shop for less den RM10 each
4. That rubber hose u are referring to i think is vacuum lines. Try installing it back.
5. With the Apexi filter your car engine now can breath easier.. as a result.. breathing noise will increase too... for the timing part... i think can readjust to 800-900rpm when idle. Ask your mech mah.. bro.. I'm sure he knows what to do.
Cheers mate.... may the force be with u :X hehehehehe...
fixed already...include the breather all settled. just wonder where to get the heat sheild. now the breathing noise not noisier, just can feel a bit when u drag...but my previous rmp is around 850-900, now drop till 800 like that. but the engine didnt shake wor...so far okay lar. but this filter not washable right???
feel any extra power?
power? for me just a bit...but can drag more long, not bad at all.especially when u drag the filter noise damm chun. somemore when i try after i installed, can spinned wheel at 2nd gear, somemore is climbing conditions. overall okay. but just cant wash only....
yupz... apexi dual funnel filter is maintainence free... dun need to wash. It can last quite long... my fren use until 50,000km already still cun... but i suggest change the filter when u change your timing belt.. hehehe approx 80-90,000kms
cheers nicteh with your new found power!
