Mivec Club
Hi to all mivecian...
I have 1 question here, i just went to tune and dyno for my mivec 1.8 + emanage...From the dyno, i got 150hp on dyno dynamics,if on dynojet maybe can get around 170hp. Is it normal for mivec 1.8???
Hi guys. currently driving a Mitsubishi Mirage, CJ chassis. Looking for a good workshop to do a 4G92 Mivec convert. Any good workshops to recommend? I know Mivec is not easy to work with. Hoping to find a workshop which is well versed in this area. Can PM me also; i dun mind. Cheers
@BlueSamurai
Wow another CJ chassis owner :D, high 5 man! Where's your location?
The 4G92 Mivec convert is easy, almost plug and play, all you need to rewire is for the 2-speed radiator. And depends on what spec the halfcut is.
@BlueSamurai
you have pm.
So anyone? in my area, mivecs have long gone and i am assuming not in any professional garage's expertise, or forte. So hoping to find a good workshop thru recommendations that knows wtf they r doing will adhere to specs in service manuals, and not just the generic engine work know-how.
WORKSHOP... All the foreman also drive MIVEC and they do modified car such like myvi,kenari yrv... me also drive mivec... if you call up just mention iswara mivec recomm u ok...
good luck on ur ride...
i want to let go exedy racing clutch 3 pucks , 8.5 inch in size. made in japan.
rm600 NEGO.
019-3843200
Guys, how much can you go for RM50 on Vpower 97?
I can only manage 180kms max..
engine is stock with 1.8 block and 1.8 conrods, 2.5" piping and 2.5" exhaust.. hurts a lot..
Hello...bro I using Mivec 1.6 manual in Iswara body...
Ron 95 RM 80 can run 490km in highway only
City 360km to 390km...
Engine STD 2 inch piping,fuel reg.. Open pod air filter...
Mivec open in 5200rpm.
Enjoy our beloved Mivec ......
Hi
anyone have any idea what's the part number of 4g92 mivec-md ecu ?
Thanks
---------- Post added at 09:56 PM ---------- 6 hour anti-bump limit - Previous post was at 09:56 PM ----------
Hi
Thanks
Hi guys.... I driving a Mivec 1.6 manual gear... Last Saturday my 5th gear kick back to Neutral went I in high speed sometime in 160km to 170km..
Guy is my gear box to RIP or just replace the 5th gear only... Help Help....
---------- Post added at 01:46 PM ---------- 6 hour anti-bump limit - Previous post was at 01:45 PM ----------
hi everybody.. i'm newby here.. currently using mivec from lancer ck fitted into my waja.. the engine reached 220k on the odometer.. simple check i found that there's oil leaking between top head cover... currently looking forward to top overhaul my engine coz making loud tepet sound but i'm not sure.. any suggestion for best mechanic to handle mivec engine in K.L / Ampang area? Thank you for your time...
Hello... Bro... I steven using Mivec engine... Do call this number 0123155955 Jeremy...
All the foreman using Mivec engine... Just mention steven blue iswara.. Recommend u... Tq.
---------- Post added at 05:03 PM ---------- 6 hour anti-bump limit - Previous post was at 05:02 PM ----------
Kuala Lumpur area..
