is the T04B is old model?Originally posted by sum-dum-fuk@Mar 1 2005, 10:17
t04b and t04e is a frame size...
most ppl measure diameter size from the inducer of the compessor wheel...the tip of the wheel where u can see... ;)
Originally posted by sum-dum-fuk@Mar 3 2005, 08:42
tkk..
there's no right / wrong size to use...it all has to calculated and also depends on what u want.. ;)
[snapback]784133[/snapback]
Originally posted by Act-4@Mar 25 2005, 14:42
[tkk...your t04e is taken from what engine..?
if i take from rx-7 engine,can i use it into 4g63??
another question...what is differt betwen GT and t0XX series..??
Thank you... :D
[snapback]840105[/snapback]
Originally posted by sum-dum-fuk@Mar 28 2005, 10:59
lv..
eclipses run a TD04... why do u wan an inbetween ?
[snapback]846294[/snapback]
Originally posted by sum-dum-fuk@Mar 28 2005, 08:33
tkk
GT does not mean all are ball bearing.
[snapback]845805[/snapback]
Originally posted by dolly@Mar 28 2005, 18:42
lilvee, are you refering 2 the 2nd gen dsms? if i'm not mistaken those use td025, faster spool than td04 but weaker top end..
[snapback]847860[/snapback]
