Mitsubishi MIVEC
tatatititututoto
just wanna ask some suggestion from all the sifu's out there... lets just say,....
I have a 1.6 MIVEC engine and ...
1) I change the block to a 4G93t block
2) Balance & lighten the engine
3) Turbo-charge the engine
4) Supercharge the engine
5) Change the cams and etc, maybe a standalone ECU, enlarged trottlebody, bigger injectors, adjustable campulleys...
6) Remove the REV & SPEED cut
Is this kindda mod possible or is this mod to 'wicked' to be done?
How will the performance be like? maybe both the supercharger & turbocharger boost @ 0.7bar... :)
What will the cost factor be like?
1) I change the block to a 4G93t block - block can get cheap about 500 bucks
2) Balance & lighten the engine - more than 2k to replace with new parts
3) Turbo-charge the engine - new turbo system or 93t ?
4) Supercharge the engine - 7k
5) Change the cams and etc, maybe a standalone ECU, enlarged trottlebody, bigger injectors, adjustable campulleys... - injectors cheap , ecu 4k plus , enlarged trothle cheap , adj cam pulleys less than 500 bucks
6) Remove the REV & SPEED cut - ur stand alone ecu will be doing it
usually people doing this will take a gsrt and put a mivec lolx..
not take mivec and put gsrt block and put turbo kit .. lolx
if u wanna do the other round.. just prepare a torn pocket
buy $ says it all ...
if new turbo kit prepare $$$$$$$$$$$$$$$$$$4
hey man i share your vision. if i was you i will do the base mods first like port and polish balance and sorts .... then save up for the turbo .... then the super charger then go for cam tuning and ecu tuning. should cost a minimum of 15k if you have frens at the mechs. good luck man wat car you driving anyway?
