mirage brakes question
dtp
hi i got an c53a mirage hatchback
i want to install rear dice brakes in my mirage
i am from the caribbean and part for c53a is very hard to come by
but other models are around that i can use
like 1-galant
2- ck lancers 1-4
3- cb lancers 1-3 also wagons
which one rear brake will work up my mirage without any problem
i think CB lancers from similar generation might work... i'm not familiar with mitsubishi model numbers... but if it does not fit, machining the drum brakes to fit the disc into it do work... many mechanics in malaysia are doing it this way... for example, mitsubishi c12 using vr4 rear disc brakes and so on...
of coz u will need to customize a bracket to hold the caliper in place... as long as the brake set is a rear brake set (with handbrake lever cable) and PCD of the lug is same, it would be able to fit...
