Microtech
Need recommendation here. What is the suitable mileage before Dyno tuning after engine overhaul ? I heard new bearing and piston need to run-in first ?
Microtech no1 again at sepang drag battle best timing...
---------- Post added at 12:05 AM ---------- 6 hour anti-bump limit - Previous post was at 12:05 AM ----------
microtech no1 again at sepang drag battle best timing...
and latest info..
World no1 stand alone ecu..
another championship year from microtech powered car in malaysia...
jo1..congrats...
no1 fastest 4wd powered satria in malaysia...and overall champ....
no1 fastest evo powered in malaysia....
all powered by lt10s..
proven to be the best bet for all your mitsubishi needs...
and other motors too...
also just clocked world fastest rotary on earth with microtech powered and world fastest sport compact 2jz....
indeed microtech ecu..injecting the world fastest cars and malaysia fastest of course!
Dear sifu
If we change new throttle body ( even with same brand but incase old TB is fault) , then we should do the setting step again for TPS in the microtech?
i mean to recalibrate to 0 position in the TPS setting... do we??
thanks
Dear sifu
thanks
Yes i believe you have to because even when I adjust my idle just a little bit also the TPS will lari and have to reset back to 0, so i think changing the entire TB will definitely have to reset back to 0 either ways after you change to a new throttle body you should have your tuner to plug in the handset and check the TPS reading just to be sure :driver:
Hi, looking for a ECU for Mitsu Airtrek turbo, in the process of converting to manual gearbox. Just want to know if U have a suitable microtech for my car. Looking for a entry level standalone using 3-bar MAP, pls advise...thanks
AvanT you can use LT10s 25 psi version. Which you can boost up to 1.5bar.
We can do it for you if your location is in Penang area. Should you wish to retain your auto gearbox with LT10s we can still do it for you as long as your stock ecu is still around. :)
Great!! Can U kindly quote me for LT10s 25psi version OR any other suitable Microtech model, need the ECU package only, I have a tuner here in KL to install for me. Pls note that what i need is a entry level for AIRTREK turbo, dun need a top of the range full spec ECU which has a lot of function which I will not be using. Thanks again :)
drill: map sensor repair if stock map 25psi rm550 + instalation
---------- Post added at 12:51 AM ---------- 6 hour anti-bump limit - Previous post was at 12:48 AM ----------
btw, we are proud to announce that the overall winner for world sport compact is powered by microtech...
so u guys using microtech...stay a proud owner of the champions choice ecu: microtech!
visit us at facebook: Joshua Thiran or Millennium Motorsports Asia
or
http://www.millennium.my
for more info!
All new microtech ecu's are now CAN BUS friendly...
this means u can just plug in a racepak dash or pcs dash straight into it..
and also...
with the all new 32x64 software is gonna blow your minds away...
the CHAMPIONS CHOICE...in all races since year 1995 in malaysia...no1....
hi,
i've manage to fix mine. thanks. and got my car tuned by jo1. its running perfectly. its not a race car, but works wonderful especially the fc. got far better milage compare to when im using afc neo.
but now im thinking to change to a tiptronic gbox. so just wondering, for my engine, the auto gearbox also give and get readings from the stock ecu. can a microtech handle those too??
im in a dilemma now whether to sell of my car and get a descent auto tranny car, but for sure i will miss the power.
Jo, for my 1.8 mivec (ca4a) model, can I use the can bus version ?
yeah u can use the canbus system..no worries.
---------- Post added at 08:44 PM ---------- 6 hour anti-bump limit - Previous post was at 08:43 PM ----------
THE MICROTECH LT10C and the LT16C is now available...
PROMOTION plus install and dyno tune for honda,mitsubishi,toyota.....RM4800...all in all...no hidden cost...
get your world no1 engine management system today!
Hi,
I have some question to ask. My fren want sell me lt10 with wiring for gsr because he sell his car. Now, i planing to buy from him. Can you install and tune for my car? How much does you charge and how many days does u need? Please advice. Tq
Hi,
install n tune would cost u total rm1300...and would take 3days
