C cmng 3,000 RPM Senior Member Sep 29, 2005 #1 anyone here have GTR brake master cylinder size for GTR 32, 33, and 34 ? wondering those upgraded to 4 pot AP or Alcon need to upgrade cylinder or not TQ and anyone have R34 GTR Last batch rear rotor ? which is 322 x 22 mm size one . TQ
S .S K A G E E. 500 RPM Senior Member Sep 30, 2005 #2 If you are talking about the standard GTR brake Master cyclinder, then there's no need to up grade for an 4 pot ...infact they are even good for 6 pots too
C cmng 3,000 RPM Senior Member Sep 30, 2005 #3 GTR 32 can use ? my problem i using bigger 4 pot front and 4 pot back
M MrNismo 500 RPM Senior Member Sep 30, 2005 #4 I think it's 26mm. I can double check it and let you know.
C cmng 3,000 RPM Senior Member Sep 30, 2005 #5 mrnismo it is 322 x 22mm i checked few time my rear caliper acceptance is max is 24mm only front is 30mm. Thank
M MrNismo 500 RPM Senior Member Oct 1, 2005 #6 cmng said: mrnismo it is 322 x 22mm i checked few time my rear caliper acceptance is max is 24mm only front is 30mm. Thank Click to expand... No, no, i mean the master cylinder size, it's 26mm.
C cmng 3,000 RPM Senior Member Oct 1, 2005 #7 opss.. thank.. emm i think should be good enough for 4 pot front and 4 pot rear kua.. any opinion ?
M MrNismo 500 RPM Senior Member Oct 2, 2005 #8 The exact data: BNR32 GTR - 25.4mm BNR32 N1 - 23.8mm BNR32 Vspec & Vspec N1 & Vspec2 - 26.9mm BCNR33 & BNR34 - 26.9mm
C cmng 3,000 RPM Senior Member Oct 3, 2005 #9 Thank In term of inch BNR = 1 BNR N1 = 7/8 The rest is 1 1/16 TQ.. i think i might need 1 1/16. let me dig more info on my brake first TQ
