Hi all owners of R34 GTT. I have some question wrt to the ER34 as follows:-
1) What is the recommended viscosity of engine oil? How many litres of engine oil are required? What are you guys using? What is the oil filter part no.?
2) What is the recommended viscosity of the differential oils? How many litres of engine oil are required? What are you guys using?
3) What is the recommended viscosity of the manual transmission oils? How many litres of oil are required? What are you guys using?
4) What is the spark plug gap that a stock/midly modded GTT requires? Any recommended brand and its part number?
5) What is the part number of the air-cond filter replacement panels?
6) What available brake pads are available out there for the GTT. Front and rear? Part no?
7) What are the recommended brake fluids to be used on the GTT? Litres required?
8) What is the part no. of the water pump?
9) Timing belt change. What else should be purchased/changed at the same time? Tensioner adjuster? Oil seals (how many)? Air-cond, fan, alternater belt? Any part numbers available for the above?
10) What is the part no. of the fuel filter?
11) Clutch. What are the original part no. and what aftermarket options are available that’s not too stiff!
12) What fluid should be use for the power steering? How many litres are required?
13) Have anybody dynoed the stock ER34? What are the bhp and Nm on the engine and wheels?
Many many thanks in advance. Thank you for helping me understand the ER34 better. :regular_smile:
