S synail Known Member Senior Member Jun 4, 2015 #1 Hi guys Can I use motor oil...lets say 20w-50 as an assembly lube?
Izso NA NA NA NA NA Helmet Clan Moderator Jun 5, 2015 #2 What sort of assembly? engine oil doesn't stay on metal for too long and will dry up if not lubricated especially for moving parts.
vr2turbo ((( God Level 30,000 RPM ))) Helmet Clan Moderator Jun 5, 2015 #3 Must be engine as he skim the head in other topic.....
S synail Known Member Senior Member Jun 5, 2015 #4 The head parts...I can't get assembly lube/paste at my area...
vr2turbo ((( God Level 30,000 RPM ))) Helmet Clan Moderator Jun 5, 2015 #5 synail said: The head parts...I can't get assembly lube/paste at my area... Click to expand... Can use engine oil. I saw my mechanic do that too. Anyway when running it is lube by engine oil....
S synail Known Member Senior Member Jun 5, 2015 #6 Thanks guys Appreciate it I saw on the net, they use motor oil or atf oil I'll go with 20-50 motor oil then
vr2turbo ((( God Level 30,000 RPM ))) Helmet Clan Moderator Jun 5, 2015 #7 synail said: Thanks guys Appreciate it I saw on the net, they use motor oil or atf oil I'll go with 20-50 motor oil then Click to expand... Header not too much to lube. Valve stem, cam, rockers and bearings.
S synail Known Member Senior Member Jun 5, 2015 #8 vr2turbo said: Header not too much to lube. Valve stem, cam, rockers and bearings. Click to expand... U r rite, I'll be fine with jez using motor oil Thanks man Appreciate it
