LSD gearbox 5speed
hello86
may i know my driveshaft can fix in LSD 5speed gearbox ( ae101 ) ?
o LSD gearbox nid put other driveshaft .... i donknow head ngam anot !!!
sorry is not supercharger !!
i stil thinking wan take which LSD anot ! very expensive ! ae101 gearbox o lsd gearbox oso very exp .... mayi b use ae92 gearbox... but donknow can fix it a not ... n ratio ngam ant !
if i fix ae92 gearbox hav power ma ??
If he talking is Supercharge gearbox, the drive-shaft is not same.
if he is using 20V engine, supercharge gearbox cant put in also..
and also if he is using super chage engine, lsd anot also will be the same..
but if he is using super charge enigne with 20v gearbox, then will be the different story..
---------- Post added at 04:19 AM ---------- 6 hour anti-bump limit - Previous post was at 04:18 AM ----------
confirmed ratio not same...
which lsd u looking for?
1.5 way or 2.0 way? or even the oem toyota lsd?
any difrent with 1.5 o 2.0 ?
may i know i can fix ae92 gearbox ?
if i fix ae92 gearbox wil los alot power ma ?
u mean 4AGE 16V gearbox or the 4AFE 16V gearbox?
both have diffrent ratio
1.5 means not fully lock..
2.0 means fully lock = both wheel spin with same speed
1.5 n 2.0 izit 2.0 are the best ?
i think my ae92 is caburetor 1 , i stil thinking wan use back my ae92 se limited gearbox anot !
donknow can fix anot . n wil make my 4throttle los alot power ??
ae101-wong ~ may i know ur hp no . ?
i cal u . can know more details !!
if u're not racing kaki it's not suitable for u to drive full lock lsd..
1 way lsd will be suitable..
1. cheaper
2. reliable
3. less disturbance of the full lock sound
if u're using se limited original engine, better use back ur model gearbox, unless u planning to change better gearbox like blacktop 5speed gearbox or the 6 speed 1...
my number is 0125300063, ivan, thanks!
now my car se limited , but nex 2 week i wan 2 change engine alredy ! 4throttle silvertop !
now i donknw my ae92 gearbox can use anot n donknow wil los alot power anot !
of corse is racing kaki lo , jus is now didnt hav alot money buy the gearbox !
i jus knw se limited gearbox ratio nt same with ae101 gearbox !
ae 101 gearbox n ae 111 gearbox manual izit is same ?
silvertop and blacktop are different also...
better get 6 speed la..
more smooth cruising..haha!
so nex 2 week me pasang the silvertop .... if nex time i wanna change 6 speed can ?
izit ae101 5 speed gearbox can fix to silvertop ah ??
sory....bro if u dont want the lsd gearbox:hmmmm: can u give the seller contac no?? tq:itsme:
pm me please....
