Latebloomer
Hi brothers of zth. Currently looking for mivec pistons for my 4g93 na set up.
Finally some answer. It had been awhile since i have chit chat at this forum. Ya was thinking on getting the semi forged piston but will it be worth it compare with the art brand piston?
im goin for high compression set up... the old piston are okay and all.. im doin general overhaul on my engine so i was thinking on changing the piston on the way goWhy are you changing your pistons? Is it blown with your current usage?
If normal usage normal compression like normal factory spec, any pistons is ok i think.
If going for high compression, semi forge better. If conservative tune, normal pistons also ok.
If turbo, forged pistons.
