Looking for Altezza...need help
Sure... Will need some advice on what to look out for in buying a tezza.
Where do u guys usually meet? I hang out around PJ/subang after work.
Poison? No need. I'm intoxicated already. Just that they're so few units fr sale n it's close to impossible to import in a recon unit given the age of the model.
dude.. u didn't check out my "Calling for Altezza TT".. thread ?
u missed it already as we just had a drink few hours ago.
check out my other thread for more info & updates for any next session.
the white 2662 seems pretty clean. quite lowered, sure will hit bottom when passing the speedbumps.
hopefully it is height or fully adjustables. i guess if you inspected and tested out to satisfaction,
just buy ... :P
Found another newer unit but driving impression seems a little more sluggish.
Its as though the autobox ecu is reluctant to down shift when accelerator is pressed hard.
But when it does downshift, the revs climb equally smoothly (to redline) to the other unit I tested.
In short, this unit's gearbox is somewhat less sensitive to accelerator paddle modulations/variations during under diff driving conditions.
Apparently, there's something wrong with the gearbox ecu that prolly needs changing. The seller said that it should cost around RM1k+
Guru's, ever experienced anything like this b4? If yes, is it true that the ecu change cost only RM1k+ and installation is only plug-n-play? Or is this a sign of a bigger problem?
