Looking for 1JZ-GTE
I didnt say vvti for 2 k also ? i said auto soarers are about 2 k plus . soarer pre 96 are non vvti which fecth about 2 k plus , i havent seen a vvti soarer half cut here before except for the chaser .
YOu obviously need a aftermarket management to run the 1jz in your altezza as the standard ecu will not match . And also the auto gearbox in the soarer will not fit . Thats why i said you need a manual soarer halfcut to get it running. Or maybe you can run the 1jz with your auto box iam not sure
your question to the diffrent gearboxes in a soarer i ll clear it up for you.
Auto soarer (cant remember the code for the gearbox a430 or something
manual soarer r154
older supra also r 154 with some diffrences to the bell housing
6 speed supra v160
5 speed supra i think its w58
altezza 6 speed manual j160
as i know... if u buy a auto h/cut then u transpant to manual,the ecu can use back but need to modified it as well... my mechanic has been done a lot b4...
