find a bigger caliper and disc set with ABS sensor same with myvi ones...else...i dun think can d.
best is disable the ABS...not many ppl can appretiate ABS.
I got news from my foreman.get a better brake pads and it will bite better.i might get one soon for my vivi...now luckily havent vibrate
one point to ponder.do u step on the brake very harshly...like frequent an abrupt stopping?
if u answer yes then try to change habit to make a better braking.
i did a firm and constant brake so the pads will bite the disc better and evenly.
didnt pose many problem so far.
All Brother here, where can i get the eg or AE brake set?
My stupid brake caliper got knocking sound when bumpy, already fix alot time also cannot solve the problem. Thinking to change the whole brake set.
You can get it from half cut shops :) i got mine from another forumer but it's EK brakes which is similar with EG and I would say the brake really perform well :) but make sure you have at least 15" rims because it doesn't really fit well in 14" stock rim :)
