Kyosho 1:28 scale ASC collection.
Kyosho Mini Z Malaysia Season Race 2013 is here.
This year, we have Mini Z Dynasty and Mini Z Element cooperate to organice the event. Please don't miss it.
Grand Lucky Draw for racer who have attend 5 of 5 races. Let's get your race machine reeeeeeady!!!!!!
Rules And Regulations.
(Update July 2013)
Car Specification
Chassis
- Open to all 1/27 on road cars, i.e. Kyosho Mini Z AWD, MR02, MR015, MR01, Firelap, Iwaver and X-mod.
Body Shell
- Kyosho, TRP and Firelap Body shell are allowed.
- Pan Car and Lemans body are not allowed in both stock and modified class.
- Judges reserve the right to disqualify a body for excessive material removal.
- All windscreens must be remaining secure in the body shell.
- Lexan Body are not allowed
Motor
- PNWC Official 70 Turns Stock Motor for the 1st race.
- Atomic Standard Motor 60T
- 1st race all racer must run with PNWC 70T motor
- 2nd race until last race, A Main top 3 driver must remain on PNWC 70T motor, others racer can choose Atomic Standard Motor 60T or PNWC 70T motor to use.
- Silver and carbon brush allowed to change.
- Motor must run with original motor can, original magnet and original armature.
Wheel
- Unlimited.
PCB Board
- Only original Kyosho, Atomic, Firelap or X-mod PCB boards are allowed. FET upgrade is allowed. External Turbo is allowed.
Battery
- Car must be powered by four AAA size batteries. No more, No less.
- Batteries must be Alkaline, NiMH, or NiCd.
- No other type of battery is allowed. / For example: Lithium Polymer batteries are not allowed.
- Extra Capacitor is allowed.
Tyre
- Any Brand: Rubber/silicone tyre only.
- No foam tires allowed.
- No traction compounds allowed on tires, or race surface.
- Tire warmers are allowed / Tires only cleaned with a 70% alcohol solution.
WEIGHT, WIDTH & HEIGHT
- Minimum weight (170g)
- Max wheel base (98mm)
- Max car length (180mm)
- Max car width (80mm)
- Max car height with wings (45mm)
Transmitter
- Any brand transmitter.
Lap counting system
- Robitronic transponder system
- Race organizer will on the lap counting system 1 hour for testing. Driver are encourage to test and make sure the transponder is place in the correct matter.
- In our pass experience, miss lap is due to driver handle the transponder not correct. Miss lap is responsible by the racer.
- Race organizer final result is the final result.
Marshal
- Drivers are responsible and compulsory to be a marshal when the other groups or mains is in racing. For example A main drivers need to be B Main marshal when B main is racing or vice versa. Penalty will be imposed for drivers who fail to be a marshal.
Race Detail
Date
03-08-2013 Dynasty Saturday 8pm
31-08-2013 Dynasty Saturday 8pm
05-10-2013 Element Saturday 8pm
09-11-2013 Dynasty Saturday 8pm
14-12-2013 Element Saturday 8pm
Mains Grouping
- Main will be justified by the qualifying hits on the race day.
Registered
- Last date to register, please refer to the race calendar
Qualifying Hits
- 3 x 5 minutes qualifying time, starting grid position to determine by the qualifying hits.
- There will be three qualifying runs for each class.
- Each run will last 5 minutes.
- For the first run, the starting grid will be staggered in a random order.
- For the second run, the starting grid will be reversed.
- For the third run, racers will be re-shuffled into heats based results from the
previous two qualifier runs.
- The starting order for each run will be based on the number of laps run in
the time allowed.
Race Format
- A Main
3 x 10 minutes final.
- B and C Main
- 2 best final result will recorded at point system.
- Point system is according to following
1st 100p
2nd 99p
3rd 98p and so on
- If there is same point occur between drivers, driver who get the best result in the best 2 final will be the champion.
- Example:
Driver A best 2 results are 1st and 3rd. Total point is 198.
Driver B best 2 results are 2nd and 2nd. Total point is 198.
Driver A best lap is 52 laps 10.00.00 for 3 races
Driver B best result is 52 laps 10.01.000 for 3 races
- Champion goes to driver A because Driver A have the best result.
Fees
- RM50 per race including track fees.
- RM5 for transponder rental for who do not have personal transponder.
Result
- There will be 5 races in 5 months. The best 4 results will be chosen to calculate position.
Point System
1st - 25 point
2nd - 20 point
3rd - 16 point
4th - 13 point
5th - 11 point
6th - 10 point
7th - 9 point
8th - 8 point
9th - 7 point
10th - 6 point
11th - 5 point
12th - 4 point
13th - 3 point
14th - 2 point
15th - 1 point
Top qualifier (Qualifying A Main 1st)
1 point
Note:
Due to limited pit stop place in Mini Z Dynasty and Mini Z Element. Participants are encouraged to well organize the pit stop area.
Any loss, broken or stolen item are not responsible by Mini Z Dynasty and Mini Z Element.
Rules will be update from time to time.
Thanks
Organized by:
MINI Z DYNASTY
MINI Z ELEMENT
Sponsor by:
ATOMIC
PN RACING
Management reserves the right to change and update the rules and regulation without prior notice.
__________________
https://www.facebook.com/minizelement
Eat , Sleep , Play Mini Z.......
New Product Introduction:
Atomic AMZ 4WD scale 1:27, suitable use Kyosho ASC / White Body .
Package Included New Car Kit 1:27 made by Atomic RC.
The RTR Kit AMZ001-4WD is built on a carbon fiber main chassis with an upperdeck made from the same material.
The double wishbone suspension allows for droop, toe and camber adjustment and the shocks come grease-filled to achieve the maximum traction.
Included in the kit the designed platform of 7.4V Li-Po battery packs,
a 2.4GHz FHSS radio system and a micro stock brushless 5000KV speed controller made by Hobbywing.
Features
- Chassis compatible with Mini-Z A.S.C series
- Professional micro brushless speed control cooperation with world leading brand HobbyWing. (Support programming adjustment)
- VMX 5000kv BB brushless motor
- Front and rear double swing arm, for F/R droop, toe-in/out, camber…etc
- Front and rear ball diff. and universal drive included
- I.A.S. grease shock for easy to setup ride height and weight balance. Excellent (7) shock absorption
- Machine cut carbon fiber chassis and flex. upper deck
- 64 pitch gears, aplenty range gear ratios
- Li-po 2S 7.4V platform
- 2.4Ghz FHSS proportional 3Ch radio transmitter include
- Ready for Lexan body. (Optional item, not include in kit)
Code: AMZ001-4WD
Source: Atomic RC
We are ready indoor carpet track for racer enjoy together with member and enjoy the fun of Mini-z....
News & Update.
MR03 Sport , MR03 VE , MR03 ASF , KT-18 back in stock.
[/URL][/IMG]
Happy racing with Mini-z .
