KKK K3T Turbo for MR2
MRMIC2
1 unit MR2 KKK turbo for sale
Spec : KKK K3T 3070MGA K26
Full serviced and used less than 3000km after service.
No freeplay and in good condition
Downpipe included and is plug and play for MR2.
Reason for sale : Upgrade to Bigger Turbo.
Was used in MR2 3rd Gen with 317 whp. (approx. 380 hp on engine)
Please call 012-3831601 for price and viewing.
Awesome Turbo from MRMIC2. :_:
Saw it last Friday night. Must wait for bonus in Dec before can buy.:cry_smile:
i am interested ... does it fit a gen 2 ? what are the price that i might see on this turbo ?
can i use my previous stock downpipe ?
im in us and i cant call till next 2 weeks. pls pm me.
thanks
plug and play = swap your ct26 with the new turbo and dont have to do any further mods to your car.
eg. some turbos require new fuel injectors/fuel pump / downpipe/ exhaust manifold etc etc
MitonCT26 said:
cheh...tot just pasang no need to worry about fabricating a new exhaust manifold :P
Yeah..you are right MitonCT26. Just remove your original CT26 and plug in the KKK turbo (with its own adaptor) into the original 225/245 mr2 manifold. Downpipe also included.
You will need to get a wastegate though.
injectors or other accessories not included.
There is a need for new fuel injectors/fuel pump when it is run on high boost. Standard boost is ok but no kick because no big difference power :).
okay....just found out there's a 2mm diff in the exhaust fins between CT20 and CT26...
i'm on leave this friday...so er...mickey right? will give you a call if i happen to pass by peejay.
okey dokey Miton. We are having a MR2 TT on Friday night at 10pm at Shell Taman Tun Dr. Ismail. (quite close to 1 utama).Maybe you'd like to join us?
FYI my 245 CT20 exhaust turbine fins shattered (cause its ceramic) at 1 bar boost on a dyno. Found it lying around the workshop floor the next day...hahaha.So I upgraded to KKK. Porche and Audis use KKK as standard equipment.
heh, you got shattered fins on the exhaust side too? hahaha...you're not alone mate...i shattered mine after 2 years of abuse since it's installed in my car. but i was pushing like 1.3, 1.5 bar bar for a year plus or so before it gives up.
about the TT i think i'll pass cos i am not driving a MR-2 (the CT20 is mod to fit in TD05 16G exhaust housing) unless MK is good enough to bring me there lah.. :P
MK : wei that's old story la...BNB now tengah tidur cos turbine kondem :P :cry_smile:
