Kelisa Performance
et5828
1,500 RPM
walau....today i did a sprint test on my kelisa
0-80 clocked 12.4 sec
0-100 clocked 18.3 sec
this is farkin slow....but car spec written is 14.8 sec in 0-100 wo...
mine somemore modded air filter,piping, and better spark plugs :(
me and my friend thats all...didnt put things in my car also...
my friend told me the time i also shock :huh:
plus my 15 inch rims are lighter than my stock rims
WTF?! :(
every 5500rpm change gear...good start also with a little tire spin
air con closed!
There are few factors may affect your 0-100 timing.
1. Air temp , Day time Or night ?
2. Load = extra stuff like sub woofer box+amp, fuel level, extra person ?
**Note: every 50kg u safe = 2 sec improve especially for a small displacement car
3. Air cond on or off ?
4. Tire pressure ? rolling resistance
5. Tire dimeter = 13" up grade to 15" any outer dimeter change ?
6. Modification to the engine was done by the skilled sifu ? Any calculation or real H/P gain through the modification ? Air fuel mixture ok or not ?
7. Engine oil ? thicker the oil, slower the car. Change to synt oil may helpful.
8. Engine tuning= is your engine in tip top condition ?
9. Exhaust dimeter = bigger doesn't means better. Must suit your engine. Remember N/A needs some back pressure for them to work properly.
If you done the above factors correctly i'm sure you will get better result.
I witness one of my friend mod his 4g91 ( DIY without correct calibration) from header to cylinder head to injector to AFC to cam gear. However he kena tapou by a slightly mod 4g91 (My Wira he he he he ). Why? Proper tuning.
Next time you try, remember to take off your spare tyre (safe some kgs), it may helps :lol: :lol:
Good luck.
P/S Safety first and make sure it will not harm other road user.
i think your 100km/h is around 110km/h actually due to your bigger rims.
try to compare with your friends car speed. ;)
god,did u did anything mod with your kelisa?
i've tried twice on 0-100
but still clocked about 18 sec :(
The time i did it is on a cloudy evening
not hot also...so it should be ok gua
no worr, stock standard, 4 months old onli.... maybe stop watch rosak gua... hehe.... but 18 sec is quite slow leh.....
I think Kelisa is a bit slow when comes to 0-100kmh test (very subjective). But the bright side of Kelisa is this little car very responsive when RPM hit above 3.5K.
omg...what happen to my kelisa...
mod air filter and piping lose to a standard kelisa
i can see my kelisa hardly move after 80 to 100
i'm using 3rd gear that time le
about 70++ i changed to 3rd gear
piping....plsssss dont tell me u mod to straight paip....
that is a worst thing u would want to do..is damn noisy and may loose power.
i tested mine last time also around 13/14 sec to 100
bullet and a muffler thats all...i remain standard piping diameter also..
how many rpm u guys change each time?
oh man...i really know what happen to my kelisa
sial my friend beside me laughin like fark only when clock 18sec
he v-tec...lanci :(
