Kelisa Major Maintenance
ondgennis
hi all,
my auto 1.0 kelisa is clocking 70+k already. It almost time for the major maintenance. What in my plan was below
1. timing belt
2. ohters belting
3. water pump
4. head gasket (slight leaking)
5. engine mounting
any ohter things miss out? pls help me add in.
items 1-4 are quite std, mostly stock parts will do the work and the cost should be quite std. What my concern is on the engine mounting as this cost the most in this major maintenance.
As i know, the original or daihatsu one will cost ~500-700. Some question on the mounting.
1. It is true that even ori or daihatsu one will also not going to last long since the engine design and 3 cylinders?
2. local made engine mounting like Schmaco(RM200per set) or thailand made TE engine (RM250 per set) mounting. Anyone use this before?
thanks for the input.
u could use local made ones for d 2 front mountings, no worries ;-)
BUT get ori daihatsu/p2 for the rear mounting...
i had a very-very high milaged auto kelisa for almost 6 years before selling it off... i've changed the front 2 mountings twice and the rear mounting once...
p/s: i miss my bot-ed white fish... shouldn't have sold it :-(
will consider your option :)
overall the mounting for kelisa is very expensive...some more only 3 >.quote]
ya...original perodua engine mounting cost around rm650 for a set...really got shocked after heard the price....better go for OEM engine mounting...more cheaper...
original mounting is better bcoz it hve hydraulic or somethings similar in it while the others u get from spare parts shop dun hve it. But does u really need to change it, if yes i myself more prefer the original P2 mounting while if financial not allow then go 4 aftermarket one since it is much more cheaper
ur mounting so fast spoil already? usually can last more the 70,000km...unless u drive like crazy fellar on the road....
I'm using "used" mounting from chop shop rather than buying a new expensive one. Still working till now eventhough gasak it like mad cow........
