Kelisa Compressor Problem
dragger
Hi all,
I got a problem here. My aircond compressor running just only about 10 sec
then cut-off.that's why my air-cond not cold enough.it getting worse in
hot day. i went to the air-cond shop.had service the cooling coil and top-
up gas, problem still not solve. then the mechanic assume my ECU got
problem bcos our air-cond system control by the ECU and not separated as
other cars. i'm thinking if ECU got problem, sure CHECK ENGINE warning
light sure on. Anybody got this problem to their cars?Thanks in advance...:regular_smile:
the air con temp sensor rosak lar...the one that control the cool temp..maybe need to check if the sensor rosak..
