Kancil 660CC EFI Conversion-Possible?
SemoSemo
Just wanna ask you guys is it possible to do a kancil 660cc EFI conversion? Will there be an improvement in HP? Worth it? What are the costs involved?? Thanks.. :shades_smile: :shades_smile:
If u get the EFI for free also I will said no to you.
Dun waste your time and money, later regret..
Straight to L2T or L5T..
Ok I've read all the comments here, but if say I'm just itching to do the conversion and don't want to go through the hassle of JPJ registration, how can it be done? 660 carbie to 660 EFi?
see, it's not impossible, but would you REALLY wanna go thru the trouble?
you'll need a standalone ecu & harness, some sort of crank trigger wheel, and lotsa efi stuff like injectors, fuel rail, fuel regulator etc... and tuning it is another story altogether. all in all, costs roughly a new engine.
teach yurself the basics of efi 1st, and you'll see it' very much s do-able.
but a typical malaysian answer wud be " easier to transplant Lxxxxx engine lorr..." :biggrin:
haihz..
haihz..
I appreciate the answer and I already do have a standalone ECU. Harness will be added on later. I'm just trying to find out what EFi engine parts can be used on a 660 Kancil. Injectors, fuel rail, fuel pump, fuel tank, etc etc are all the things I have already taken into consideration. I just can't find enough info on a cylinder head that'll fit together with the intake manifold and block. Cost is not a problem. Ideas?
i for one, am not familiar with kancil's motor or any of the L series.
for ease of installation, can you use L2's intake manifold with kancil's head?
everything got there - TB, plenum, injectors n stuff.
since i know a buddy over here hybrid'ed a 850T (look fer username 'flamefox') i know some kancil parts fit the L series but dun quote me on that, ask kancil guys more on that!
that, or you'll looking on a custom plenum setup.
OR...
since you've already have a standalone, get 3 throttle body, custom intake with injector buns welded on and go ITB's. now THAT is something you just don't see everyday. :biggrin:
