Kaitenaz Racing - StiffRing
halteche6k
What is Stiff Ring ?
Improve Handling, Reduce Noise, Eliminate Vibration
Stiff Ring made of special formula alloy aluminium. It used to correct the car body basic geometry by filling the gap between the sub frame bolts, sub frame and the car body bolt hole. Car engine, transmission, suspension and the body shelf are mounted on the sub frame. Thus, correcting the geometry setup with Stiff Ring, the car handling will be improved significantly. By eliminating this free gap, vibration to the car chassis & undercarriage will greatly reduce. This helps to protect & prolong the car undercarriage parts life span. Eg: Steering rack, lower arm and etc.
From the picture you can see the bolt used to tighten the sub frame and the car body has a gap in between. This will cause the sub frame and body to be misalign and thus lead to a handling problem and produce noise on the uneven road surface.
With the Stiff Ring in proper place, the gap is filled up to stop the movement of the sub frame and the car body forever and provide ideal alignment between both, as a result of a perfect geometry setup.
Speed Mod Stiff Ring is manufactured in Malaysia, thus the cost is reduced compares to other imported brands. We have used special formula alloy aluminium material without compromise to the quality and effect of the Stiff Ring. Our product is strictly controlled under strong Quality Control. There is no doubt to our Stiff Ring quality.
PRICE : MYR$1XX onwards
PLEASE EMAIL TO [email protected] OR CALL 603-5635.5351 FOR MODELS AVAILABLE FOR YOUR CAR ANDTO MAKE ARRANGEMENTS FOR APPOINTMENT
CONTACT US
KAITENAZ RACING SDN BHD
8, JALAN PJS 11/16,
BANDAR SUNWAY,
46150 PJ, SELANGOR D.E.
TEL : +603-5635 5351
FAX : +603-5631 6351
EMAIL : [email protected]
WEBSITE : http://www.kaitenazracing.com
FB : Kaitenaz Racing | Facebook
KAITENAZ RACING is one of the PIONEER AUTHORISED DEALERS for STIFFRING..
CALL FOR APPOINTMENT at 03-5635.5351
