Jasma Cam Shaft
Jasma Cam Shaft
SR Performance
Jasma Cam Shaft
Product Description
  • JASMA high performance camshafts are designed to optimize torque and horsepower over the widest possible power band. Each camshaft application is offered in multiple profiles, each with their own lift & duration characteristics to suit various levels of tuning. Lower profiles offer substantial gains in power and a broad useable power band with little compromise in drivability. Higher profiles offer greater increases in power, but are tailored for the higher RPM range and racing applications.
  • JASMA camshafts are machined from new cores which are constructed from a high nickel content iron alloy. By manufacturing all camshafts from new cores, JASMA are able to produce camshafts that are equal or exceed the quality of the OEM units that they are designed to replace. JASMA camshafts are direct replacements (Plug and Play) and are designed to be compatible with the factory valve train components.
  • Excellent all purpose spec. Works well with OEM Springs.
Specification
  • Mitsubishi 4G93
  • Mitsubishi Evo 1/2/3
  • Honda B16
  • Toyota Levin Stage 1
  • Toyota Levin Stage 2
  • Toyota Levin Stage 3
For more info pls call or sms SR Performance at:
012-7306591
COD / Send by courier
https://www.zerotohundred.com/forums/attachments/448409.vB
