iswara (M) 4g91
iswara (M) 4g91
iswara204
Guys, this is my second car since december 2012. Under used and i felt it is better to let it. Below is the details of the car.
1) 4g91 engine + 4g93head(stock standard), mountings modifed
Used only CASTROL MAGNATEC all the way, and i service perfectly before 5k, No
tepet noice
2)4g91 intake manifold + 4g91 injectors + 4g91 TBody
3) manual gbox(clutch pump type), 1.8 fly wheel with exedy cluth plate used
only PENZOIL, change every 15k
4) 4g91 ori ecu+wiring,
5) gti exhaust manifold
6) vr4 single pot front disc brake
-just skimmed the disc + cross drilled the disc
7) power steering rack
8) sm4 brake servo (twin layer) complete with master pump
9) Complete 4g91 dashboard with digital meter modified untuk saga/ iswara,
Takde gegar at high speed. complete fit sampai hand rest. MODIFIED TO FIT
SAGA/ISWARA
10)VR4 Rear Disc Brake, Disc Skimmed and Cross drilled
11)GAB adjustables for iswara – baru pakai 2 bulan, warranty ada 10bulan
perfect stiffness untuk road comfy.
12) 15" Super Light Enkei Japan Rims, Dont know what model is it.
Slim 12" Radiator fan
Modified Door trim to fit Lancer dashboard
Short Shifter
Pivot Turbo Timer
Modified Petrol Pump with tank
Recaro Fish Net
*w/o the current rim, standard rims will be given.
please call, 0192932929 if your interested. Thx
