Iswara Handling Problem...
cOoL_mILLeNnIuM
yOoOO...guys do u anyone know how to improve the new type iswara handling?? I'm newbie here need some advice for my ride...thanks prosss~~~~ :huh:
want to improve ride?easy...change to a harder absorber plus with a stock spring...that will make ur ride more easier to handle at high speed...and take off that noisy exhaust...change to a quiter exhaust...
yah yah... due to da weakness of material of iswara chassis, it's good if u look into strut bar to strenghten da chasis a bit... i've done it, can say da cornering a bit smoother lor... da car wont bend till so terrible..
if u want better, high speed cornering, go for stiffer springs and gas shocks...
just use APM sports spring on the stock absorber.....but don't cut it !!!! and there u re....u can outperform all other cars on winding roads/cornering.....but make sure u re on 195/50/R15 rubbers & nothing more or less....
another solution but sure will cause trouble to FC
change the rims to bigger
if not.....like me..taking corner at 40 kmjh (sharp corner ) also bodyroll.. :(
No need to change every part etc..
Just go for multipoint strutbar/fender bar. You'll
feel the different.. Especially the fender bar.
You guysl know where to find it..
*this isn't an advertisment, just my opinion..
Originally posted by SkYwAlKeR@Apr 1 2005, 02:45
size of tyre also effect da use of certain springs meh??...
[snapback]858842[/snapback]​
ya the original 175/70/R13 & 185/60/R14 tyres in iswaras have larger sidewalls & they will flex to a certain extent at corners & you will still feel the car swaying away even with the sports springs, so best bet is the 195/50.......going anything more bigger will not be good for the wheel bearings & drive shaft !!!
Originally posted by simon+Apr 4 2005, 09:45 -->
QUOTE(simon @ Apr 4 2005, 09:45 )
--QuoteBegin-SkYwAlKeR
@Apr 1 2005, 02:45
[snapback]865839[/snapback]​
[/b][/quote]
buy improve spring n absorber.......damn chun...
but total cost around 1K depend u budget lohhh..
if not apm spring mix with monroe absorber lohh.
[snapback]856998[/snapback]​
simon man bro..i couldnt agree more..my saga despite being slight heavier than iswara wit da metal bumpers wit only cut wira springs in front( why wira? i dont know how it got there) which is considered stiffer than saga's spring n stock standard spring at the rear can still carve corners like they were on rails..hehe..maybe thats a bit exaggerated..i've kicked ass a lot of cars man..now i believe wat Karamjit Singh said about how good the saga handling is..anyway my rims are 15 in BUT wit an offset of 20mm..thats very wide n i got the fenders rubbing wit tyres..but i dont care..but now im searching for rims wit more of a std offsets.. :P
yep...the saga/iswara handling is very good with lowered springs....since wira standard spring is already short i believe u did not cut much....last time with my iswara aeroback on apm springs i also has blown away lots of racing wannabes at winding roads....so thats why i am recommending it. anyway i think its best to stick to close to standard offsets, too wide will cause wheel alignment to run out often.......
my setup and happy with it even at coners..:
15" rims wif 195/50/15
3 point bars at front and rear..
adjustable abs front with sport spring at the fronts n rear..
i'm damn happy with this setup edi.. :P :lol:
Originally posted by antonio@Apr 5 2005, 15:21
The Bars...
where to find?
how much?
how many type??
[snapback]870577[/snapback]​
bar??... ultraracing bars ar??... i planning on fender bars... hopefully can strengthen my car chassis for better cornering... after dat only plan on suspension setup lar... no money leh... :P
btw, anyone know got cheaper fender bars around ar??... or only ultraracing producing them??.. i dont want too ayam brand type lar... expensive a bit but cheaper than ultraracing ones...
thanks ar sifus sifus..
