evoX2 1,000 RPM Senior Member Dec 6, 2006 #1 may i know if B16A big V intake manifold perform better than B18C GSR?? is it swapable or need to change TB as well?
evoX2 1,000 RPM Senior Member Dec 6, 2006 #2 anyone used Blox Racing intake manifold before? the design same as skunk 2.
hattech-v Over 10,000 RPM! Senior Member Dec 6, 2006 #3 of of my fren using it... coz u 1.5k if not mistaken. n yes the design almost close to skunk2 punya design... ur head is p72 rite?
evoX2 1,000 RPM Senior Member Dec 6, 2006 #4 if get from ebay will cost around RM900 exclude tax/duty how can i find out the code on the head?
hattech-v Over 10,000 RPM! Senior Member Dec 6, 2006 #5 its stated there p72 n using terbalik punya intake manifold. sure u running p72 head...
b-eater Known Member Senior Member Dec 6, 2006 #6 can i see hows the design looks like?? got picture?
evoX2 1,000 RPM Senior Member Dec 7, 2006 #8 P72 ori with 60mm right? can swap with B16A manifold? any performance diff? terbalik vtec sound not loud due to the dual stage chamber
b-eater Known Member Senior Member Dec 7, 2006 #9 hattech-v said: will take the pic later Click to expand... hattech got the picture edi arr?
evoX2 1,000 RPM Senior Member Dec 8, 2006 #10 b-eater said: hattech got the picture edi arr? Click to expand... u want the pic of terbalik manifold?
J J101 1,000 RPM Senior Member Dec 11, 2006 #12 lotsa things on the net if you do a websearch http://www.prostreetonline.com/buy/blox_intake_manifolds/ b-eater said: i wan to se the blox one. Click to expand...
