Info Needed.... about L2s Engine
valve
Every morning.. When I started the engine.. the rpm will go high.. then its go down slowly when the temp. indicator begin to go up... the engine sound smooth and everythings normal....
But....
After the temparature indicator reach to its normal position... some tak.. tak.. tak.. noise came from the engine... and I don't think that sound is normal... coz I been using perodua engine before this... and its sound much smoother... If I'm not mistaken... the sound came from the top of the engine.. somewhere around the cylinder head...
Was it valve gap problem.... missmatch Of engine oil...?
(I'm using Penzoil fully Synthetic oil)
Anyone experienced these before..? Then guide me how to solve it.....
Extra info needed:
*What are the STANDARD GAP CLEARANCE for INLET VALVE AND EXHAUST VALVE in L2s engine....?
that's maybe gearbox sound or teppet sound..normal for l2s engine..if teppet, u can adjust it back..if gearbox sound just ignore it...unless u got money to cghange gearbox..lsd..slurppppppppp
