-= Info about Caldina GT-4 =-
ZTH
The new Caldina is derived from the Avensis platform, with the same 2700mm wheelbase. Basically, the engine and 4-wheel-drive system are carried over from the old car, which in turn took the mechanicals from the mighty Celica GT-4.
The engine is a 1998cc 16V Turbo, pumping out 260hp and 239lbft, unchanged from the old car. The 4WD system employs viscous coupling to distribute power between front and rear axle, in addition to a Torsen limited-slip differential between the rear wheels. Again, this is the same as the old Caldina and Celica GT-4. Transmission remains just a 4-speed automatic, although it gets manual shift pattern.
However, compare with the old car there are still a lot of new items. Most notably is the sharper and handsomer new look, the much higher quality interior and the introduction of double-wishbone rear suspensions from the current Celica.
Lesser models are powered by a 152hp 2-litre 16V engine (which has no relationship with the turbo engine) with direct injection, or a 132hp 1.8-litre 16V engine, both with VVT-i. The 1.8 unit is for FWD only.
Taken from : http://www.autozine.org/html/Toyota/Avensis.html
My questions : ( especially to those that owns a Caldina Gt-4 )
Generally,
1.) Is there a shiftronic (transmission) system for Caldina ?
2.) What braking system does it use ?
3.) Spare parts / Performance parts availability in Malaysia ?
4.) Fuel consumption ? How large is the fuel tank ?
5.) 0-100 km/h reading ? stock reading.
:_: Thanks in ADVANCE :_:
zth,
so sad no one reply u here........
reason is a lot pro here not driving this car man.......lol........mahal la.......
here a lots of se ae ke.......
the best u can try is go to toyota wish website/club to get it......cause there is few owner in the club.......wish u have it
not much of feedback though..
just my personal feedback. correct me if i'm wrong.
1.) Is there a shiftronic (transmission) system for Caldina ? if not wrong, i saw numbers of caldina halfcut from JDM and most of them shiftronic. if you happened to found any manual. big bucks.
Toyota Caldina 2.0i 16V 4WD TZ-G specifications
Toyota Cardina Main Page
some other info and specs
enjoy!
