Re: Increasing power on Satira 1.3gli
1.Performance cable cannot help in increasing stock engine performance...better stick wif stock cable...Mayb u can think about the iridium spark plug,but the platinum spark plug adi enough for 4G13/4G15.
2.VS juz stabilize the voltage for the electronic stuffs oni,not much improve in engine response....but VS+grounding cable kit will works...
3.yup,sure....
4.Yup,if wan comfort juz stick wif stock...
5.Adjustable cam pulley not works if u still in oem camshaft....
Juz my 0.05 cents nia....
Lighten crank pulley will improve ur engine response....
Will this mods help my car -
1. bosch performance plug cables and bosch super 4 plugs
2. Original pivot raizin volt stabilizer
3. Change gearbox oil (manual)
4. Change new suspension using stock suspension for comfort
5, Adjustable cam pulley and lighten crank pulley
I am currently using castrol magnatec 10w-40 semi synthetic, any comments on this oil.
3.yup,sure....
. However grounding cables on my ancient wagon helps the idling + revving VERY slightly. I tried removing them and driving again, the response wasnt there...
