Inaccurate fuel gauge -- Help !
Green06
Hi, Bros, need help here...........fuel gauge always show 3/4 mark even the tank is empty. Will show/indicate full when actual full tank.:confused: Have replaced complete float unit (brand new from Wing Hin) still the same.:banghead: Have even replace the fuel gauge still the same.:bawling: Any help appreciated.
U r right, I replace the whole meter yet still the same. Float sensor no problem, fuel gauge no problem.............have to be the wiring. I suspect the accessory guy must have tap into it that cause a fixed voltage to the fuel gauge. Will have to go back to the guy, but it have been 2 years since..........:rolleyes:
maybe ur float stuck somewhere......last time i kena 1 time on altezza the float stuck at 1/4 tank even pump full......:rofl::rofl::rofl:.........dun worry i got a whole fuel tank with me....:biggrin::biggrin::biggrin:
Hi Bros, I think I've fixed it. :biggrin: Removed the float unit, hooked up harness & tried it with ign. on, works perfectly. Reinstate back with ign.on and seems to work, Will have to confirm running a full tank next round.:idea:
No need to drop fuel tank....can be reached in situ, no problem....lesson learnt...always hookup with ign on before reinstate, do not know why it had to be that way, weird.
