Improve braking system
Get a better brake pads as all otai mentioned, if not upgrade ur rotor size & may help a lot more too! Still cannot then consider Big Brake Kit!:)
Larger brake servo pump will help too. If no place to fit in, then add vacuum servo....
change brake pads enuf edi......how fast u wanna go?
Brake pads also buy the correct one for use. Don't see 800 degree, wah! this one better, then find out don't work well when cold....:mad::biggrin:
Trestor blue advantage pretty good for me. Bite also much better but one thing, dust like hell....:hmmmm:
imho... if u want good brakes... pls for the love of god dont complain about dust.
its like asking for super grippy tires but expecting it to last 1 million km....
Mine is not complaining, I love them for the bite, just inform in case they use and come back say dusty.....:biggrin:
You can also try changing to steel braided brake hose, i've seen some claiming after changing, they get much better brake response compared to stock...
i'm using 800 degree rapidstop now. works well in cold too but have to bear the heavy dust. might try ebc green after this or endless pad
How much are the RS pads? Long time ago ask was RM280 for my ride. EBC green at RM350, but heard some mention very fast wear. My Trestor only cost RM120....:driver:
bought at RM450. EBC green less dust right? but i google at RS pads they produce 900 degree pads now with minimal dust. :hmmmm:
I have an inspira, and can testify that the stock brakes are crap. Upgraded to aftermarket brake pads for improved braking but the sponginess was still there. Changed to supercircuit steel braided brake hose kit and it solved it.
If i change to bigger rotors (on 16" rims), do I need to change to bigger calipers too?
