Imported valvoline fully synthetic syn power xtreme 5w-30 engine oil
Apache91120
SynPower® Full Synthetic Motor Oil
Delivers the ultimate motor oil protection and performance. Compared to conventional oils, SynPower:
Provides excellent engine cleanliness through superior sludge and varnish protection
Helps reduce engine wear at high temperatures with improved viscosity stability
Provides outstanding high-temperature protection under severe driving conditions
Provides superior cold-temperature protection through faster oil flow at start-up
Provides durable low-volatility anti-wear additives which remain in the oil longer for outstanding protection against friction and wear and have less impact on vehicle catalytic system
Helps maintain fuel efficiency for the life of the oil (applies to 0W-20, 5W-20, 5W-30 and 10W-30 grades)
Is fully compatible with all conventional and leading synthetic motor oils
Valvoline SynPower synthetic motor oils are high performing, high-quality oils formulated with full synthetic base oils and top tier additives to provide an increased level of performance. All of Valvoline's SynPower synthetic motor oils are API licensed to ensure quality for North American vehicle application. We have specially designed Valvoline SynPower 5w40 for application in high performance European or diesel passenger cars and this oil carries the specific OEM approvals such as Mercedes Benz, Volkswagen, Porsche and BMW. Our North American SynPower 5w20, 5w30 and 10w30 exceed ILSAC GF-5 requirements and carry the API starburst on the front label. Valvoline SynPower is designed with extra levels of detergent and antioxidant to provide outstanding deposit and heat protection.
SynPower full synthetic motor oil is formulated with a balance of high quality ingredients such as detergents, dispersants, antioxidants, friction modifiers, anti-wear additives and premium base oils that work together to provide exceptional protection against engine stress and wear.
Valvoline's proprietary formulation includes special anti-wear chemistry. Valvoline's low impact ZDDP allows phosphorus in the anti-wear additive to stay in the oil longer than other leading synthetic motor oils. Phosphorous bonds to metal parts in the engine to form a "sacrificial" layer that helps protect against friction and metal wear in the engine.
SynPower uses premium detergents and dispersants that protect against deposits and sludge to keep engines clean. SynPower's premium full synthetic base oils and additives hold up to extreme temperatures to provide increased protection for your engine.
MADE IN THE NETHERLANDS
TEL: 012-9154001
