Ignition Timing Acceleration Adjustment
Johnny_9
Refer to the adjustment map.........sifu's
Acceleration Ignition Map - Ignition timing can also be corrected for a rapid change in the throttle opening rate for a smoother transition into wide open throttle.
http://www.mohdparts.com/emanage/ultimate/features/index.html
See the link above - u can also see the manual
The above table is blank - but u input the IGN timing
In the bottom row of the table is the Time in ms the correction is effective e.g 20 ms.................
