ignition advance on BT 20v
Skassa
Hi All.
I have installed a blacktop 20v in my ae86, and used a Vems ECU, to take full control over all the things,
I right now run 28 degrees advance at WOT,but would like to know if anybody knows what advance it drives at WOT, with the OE ECU,
or what You guys have used at WOT to get max power,om a standalone ECU,
right now it feels a bit slow.
Let me hear your input.
Regards,
Skassa
No, no misfire at all,
Just not as powerfull as i would think, i only at 110 wheelhp,when i measure it with my Gtech,
So i just want to know about how much advance someone else is running at wot
/Skassa
Thanks,
Yesterday evening, i tryed to up the advance to 35degrees at wot,and there is a big difference, much better,
This is with a 12.5 AFR,
I just need to get on a dyno,to take the advance closer to the egde,as i cant hear if it´s knocking, over the noise oft the ITB´s.
This will be easy on dyno,
I have now heard fom others ,that some have run up to 42degrees at wot.
Regards,
Skassa
