Hyundai Elantra extractor
limch1
1) You wouldn't get any signal at all.
2) THe CEL light will light on due to the uncorrect location of your 2nd O2 sensor. THis can be overcome by eyither discon the light at the panel or re locate the 2nd O2 to the correct position( this take time and testing).
Hi Deep$hi+$
How do I disconnect/disable the 2nd O2? Or how do I disconnect the light at panel? Meaning I will not get any CEL warning at all?
Thanks
charles
Got the solution, need to get a O2 simulator.
The simulators effectively fool your vehicle's OBD-II computer into "thinking" the factory catalytic converters are installed and functioning properly.
www.o2simulator.com
Hope can easily find it in M'sia.
o2 simulator ah....
If cheap, can buy. If expensive don't lah. Will haunt you back later.
Diconnect the cel light. Easy lah. open up the meter, take the bulb out then no CEL anymore lah.
hey bro, anywhere to find that o2 simulator? Seems like the easiest is to get the bulb out, damn!
Kinda used to the 'check' light always on now... Maybe when free will try to take out the bulb.. hahaha
Originally posted by HMS@Mar 10 2005, 02:09
i tot it won't function in OBD-II??
better double check
[snapback]804552[/snapback]​
