Hydro Booster Fuel Saver
hydris
My Hydro Booster is a new generation hydrogen generator that produces only Hydrogen and Oxygen at low amp and will not over heat.
It is made of stainless steel and can stand the heat in the engine compartment.
It can save fuel up to 50% and increase power up to 15%.
This product is back with money back guarantee if no fuel savings is achieved.
It can be serviced easily and parts are readily available.
Suitable for all types of cars i.e. petrol, gas or diesel. From 600CC to 2000CC. For more info, please refer to the following link:
http://snipurl.com/hydrogo
what abt modified cars?
im running 4agze supercharger
does it have an on/off switch where i can choose whc to use everytime?
Yes, it can be installed in any cars either turbo or supercharger. You can add a switch at the dashboard. If your live wire is from the ignition switch then u need to have a 10amps fuse but you don't need a fuse if you attach it to the wiper motor live wire.
any product liability?
any safety measurements?
how long is the warranty?
what is your guarantee for money back? and how long?
can add indicator for low water warning LED?
how long does a full tank of water last?
---------- Post added at 10:51 AM ---------- Previous post was at 10:43 AM ----------
what about rust issue?
FYI, this product is a simple DIY unit. Guarantee is only given to the product performance. i.e. on fuel savings. For that matter, guarantee is given to customer when installed by seller only.
Since the product is stainless steel and has no moving parts, wear n tear is minimum. Parts is easily available. All parts are replaceable and easily assemble.
Stainless steel rust? However, the electrolyte will turn cloudy or rusty due to minerals in the filtered water. So maintenance is important. It should be done every 1 or 2 months by the owner or seller. Servicing cost is RM20 only.
The kit comes with an indicator light to indicate the condition of the electrolyte. It will turn off or dim if there is no or less water in the tank.
Yes you can install an LED light but need to do additional wiring. Additional electrical works shall be at the owner's cost.
For the 1/2 liter tank will last about 400km or 4 hours of driving.
Tq for the enquiries.
ok, what abt product liability?
as im in Sarawak, its obvious that u cant install for me right? Thats why u need to show me exactly how its going to work
My assurance on the product is if it doesn't work a week after installation, just return it for full refund. I will email to u the installation procedure photos when u purchase the product. Since you are in miri, I'd suggest you try find a similar product within your vicinity or survey among ur friends who has installed any hydrogen generator in their car so that you get an idea how the generator works or better still try surf youtube under the title of hydrogen generator. There are plenty of info in there.
Thank you.
if it can svae fuel, i wud be happy to buy. can i become your reseller in my area so that i can push your products as well?
Yes, I'm available.
---------- Post added at 01:24 PM ---------- Previous post was at 01:15 PM ----------
Recently i've installed in a 4age engine....after some study on turbo and supercharger, any changes to the pertrol octane will affect the engine....inducing hydrogen and oxygen will increase octane rating and this will affect the system. My concern is the early detonation. I'd suggest you refer to anyone that has installed hydrogen generator on supercharger or turbo engine.
Installed in a Kembara and the fuel consumption is half tank from Ijok to Pontian. Standard consumption, 1 full tank. It's true, try for yourself....50% savings....
