how to tune the skyline GTT AUTO GEAR???
iloveskyline
does e manage suitable? i just wan to do some research niah...ehehehe...
i don hav GTT...:rolleyes: just hope get 1 gtt in the future...
Bump: nobody here????haiz...
Bump: :confused::confused:nobody here????haiz...
Bump: nobody reply me de???why???
yes emanage suitable. many people here using emanage with good results n very satisfied... u will never go wrong with emanage...
e manage can + how many HP????
Bump: does e manage any bad for the car???how much is it?
Got this from the net, but not really sure it helps.
NISSAN SKYLINE ER34 GTT – STAGE 1 TUNING GUIDE
Under the hood (stock 140 to 150rwkw)
The R34 GTT replaced the Nissan Skyline R33 GTS25T and features a upgraded version of the RB25DET. The main difference is the NEO head which has a new variable valve timing system, revised cam profiles, and solid lifters. Power was increased to 206kw with more torque available earlier in the rev range. The turbo has slightly larger exhaust housing and a nylon compressor wheel. Cooling has also been improved with a larger more efficient intercooler.
Engine Tuning Stage 1
Exhaust (around 160rwkw)
The RB25DET NEO is a sweet sounding engine but very quiet in standard form and as with most factory turbo cars the exhaust causes a huge restriction. A good free flowing exhaust will have the RB sounding great, turbo lag will be reduced, and power gained throughout the rev range. The new exhaust should start from the turbo with a dump pipe either a 3" open bell mouth or better still a split dump to separate the gases from the turbine and waste gate. From here a high quality 3" high flow cat should be used, then 3" all the way to the back of the car with high flow mufflers.
Intake (160 to 170rwkw)
Now we have the exhaust side of the engine breathing the next step is to get more air into the engine. Either use a high performance air filter, or replace the air box with a POD style air filter. If you choose to go the POD filter route I recommend you fabricate some type of shield to keep hot air from the engine bay away from your intake. A cold air intake to the filter from the front of your Skyline will also give you a performance advantage. 5-10 rwkw is achievable with this mod.
Boost increase (175 to 185rwkw)
In standard form the R34 runs a two stage boost control system 5psi to 4500 rpm then 7psi to red line 7000 rpm. As mentioned before the turbo’s exhaust wheel is ceramic and they tend to fail if to much heat is generated. The amount of boost you can run with the stock turbo is debatable but I don’t recommend running more than 10 psi. You have a few options when choosing to increase the boost either a manual boost controller, electronic boost controller, or a new wastegate actuator.
A manual controller is very basic in its operation it bleeds off air causing the wastegate actuator to open later. The amount of boost run depends on the amount of air bled form the system. It is critical to install an after market boost gauge before carrying out this modification as the stock gauge is not accurate enough and is measured in mmg not psi or bar. Manual boost controllers are cheap and easy to install but they do have there disadvantages some can cause
Boost spikes and boost creep I have also found boost tends to tail off high in the rev range.
Electronic boost controllers on the other hand use stepper motors and monitor boost about every 10th of a second because of this boost spikes and boost creep are kept to a minimum, and the desired boost level is held to redline. Electronic boost controllers are expensive and for this level of modification a manual controller will probably be good enough.
A 3rd option is to install a different wastgate actuator and the good news is the R32GTST item is exactly the same as the R34 except the spring inside is set for 10psi. R32 actuators can be hard to find but I think it’s the best option for this level of modification as boost spikes and boost creep are eliminated.
No mater which system you choose the 2 stage boost control system should be disconnected. After this mod is carried out many people notice flat spots throughout the rev range this is due to the ECU seeing an increase in airflow and as a safety precaution it richens the air fuel mixtures. Many people find re-gaping the spark plugs from 1.1mm to 0.8mm fixes this problem but if it does not you need to consider the next upgrade.
ECU (185 to 200+rwkw)
As mentioned before many people have problems with flat spots and rich air fuel ratios. Even if you don’t have these dreaded flat spots an aftermarket ECU will give good power gains and improve drivability. One popular option is the Apexi SAFC (Super air flow computer). The SAFC is a piggy back to the ECU and works by tricking the ECU into thinking your engine is getting more or less air than your engine actually is. Tuning should be done be a professional on a dyno this modification should fix those dreaded flat spots by leaning you air fuel ratio's at different RPM points.
A better but more expensive option is the Apexi Power FC which replaces the standard ECU. Many people choose the Power FC as its less expensive than other aftermarket ECU's, and it plugs straight into you old loom so there is no need to cut any wires. All parameters of your car can be tuned with a Power FC but once again it should be dyno tuned by a professional. Please note the power FC cannot be used an automatic transmission.
Clutch and Fuel Pump
At this level of modification it’s likely that your clutch and or fuel pump will need upgrading to handing the extra power.
Conclusion
This completes stage 1 engine tuning for the Nissan Skyline R34 GTT. Basically at this stage we are at the limits of the standard turbo and fuel systems but in terms of car modification this level of tuning offers great value for money. Many people with these modifications along with well sorted suspension and tyre packages have 12 run second quarter mile passes.
