How to know whether its an ori r?
The Spec-R differed from previous Silvia models by featuring a 6-speed manual transmission. The Spec-R also included extensive chassis and suspension strengthening via the use of larger anti-roll bars and strut bracing. The S15 featured the same 4-piston front brake calipers that were found in the S14 but included a larger brake booster.
One of the biggest changes to the S15 model of the Silvia was the implementation of a helical limited slip differential. The result was a safer, more track suited drive; in some contrast to its drifting heritage and subsequent media attention.
As with many Nissans, HICAS (High Capacity Active Steering) four wheel steering was available as an option.
Bro alray. All you mention can be convert just by buying a full cut. Thanks bro lan evo. So that means the chassis tag is different.
