how to get on the tracks?
Noob
haiya guys,
i wanna learn how to drift n race on tracks!!
where can i learn how to do so? are there any requirements (e.g. age,car)?
using a stock car tho(honda city).. will that make it impossible to do so?
cant mod it coz it's my sister's car..
anyone know any cheap circiuts around klang valley for noobs to practice?
sepang is kinda costly..( RM 150 per driver) too malu to go there with the city also :ph34r: ..
thank you to all the sifus that reply!
you cannot drift on track. they will flag u down.
any car in good working condition with no leaks is allowed.
here's some advice from MK84:
Originally posted by "MK84"+-->
QUOTE("MK84")
You don't know until you've actually driven on the track
You will get stone chips and scratches if you do this:
1. Go into the kitty litter
2. Follow a car that's been to the kitty litter to closely.
Tire wear depends on your alignment and tire pressure, and also your driving style. If you drive as if you're driving on normal roads, you tire wear is actually less, because the surface is very smooth compared to normal roads.
The thing you need to watch out for when driving in Sepang is:
1. Brakes. Sepang is very demanding for brakes. The two long straights mean you'll be doing a high speed braking from top gear down to 2nd. And most standard brake system won't last more than 3 spirited laps before fading.
2. Water/Oil temp. Another big issue. With two longs straights, and plenty of high speed sweepers you'll be at 90%-100% throttle for quite a bit. While your engine water temp might be able to cope with it, the oil might not. Keep your laps short, 3 laps is about the max most car can handle. Also make sure you do a cool down lap before entering the pits.[/b]
by mist:
--QuoteBegin-"mist"
as MK said, pls do a cool down lap before pitting. let the fluid temps stabilise and cool down, and also the brakes. but also keep a lookout in the rearview mirror : i've seen plenty of idiots who are on a in-lap getting in the way of others who are going at full racing speed. :evil: also, for those who've never been to track before, here's a handy tip : don't put your handbrake up when you're stationary - you'll warp the disc.[/quote]
ooo... nice tips man
thanks lots..
arent there any other race tracks around klang valley other than sepang?
n where can i learn how to drift?? :ph34r:
please do not use your sister's car. there is no insurance coverage for accidents on race track. you mighty well spend RM4k on a Tiara beater with no leaks to "learn". rent a car from the airport if you have to but don't punish a perfect running road car. they have feelings too :(
Originally posted by simonchangwaimun+Mar 30 2005, 22:26 -->
QUOTE(simonchangwaimun @ Mar 30 2005, 22:26 )
noob,to drift,pls visit the drift section or www.drift.com.my
in klang valley,no more other tracks
they had close down bt3 track
[snapback]854942[/snapback]​
[/b]
yeah. or visit the drifting section for the `off the road' sessions. best way to learn how to swim is to throw yourself into the deep! :P
--QuoteBegin-coldfish
@Apr 1 2005, 14:37
[snapback]859606[/snapback]​
[/quote]
well said. go buy something shitty and turn it to pulp. :)
wanna get a 2nd hand car.. but aint got no cash.. i'm juz a student..
damn sad
probably try to get unc's 230e that had been sitting there for a whole lot of years bcoz it cant move at all..
den can convert it into a drift machine cum track car cum everyday car! muahahahah.. 3in1! that's better than nescafe! :lol:
tayar. brake. oil hitam. rad water level. throttle cable? lol
if got extra dosh/money do balancing front tayar so wont wobble so much on da strights.
:ph34r:
hahaha melted my throttle cable during my first outing! along with the clutch cable. luckily got time to go out n buy 1 set, and install in the pits. went out again like nothing happened...
Originally posted by khoyos+Apr 8 2005, 17:26 -->
QUOTE(khoyos @ Apr 8 2005, 17:26 )
--QuoteBegin-pimpin323
@Apr 7 2005, 01:08
[snapback]879835[/snapback]​
[/b][/quote]
wow.. thats scary.. is it that hot while on the tracks?
few tips
-dont push the car to much if its your daily driver. rev limiting
-dont chase faster cars. eg. if driving kancil dun cucuk subarus. very tempting
-know your braking point. 100 to zero in a safe distance
-but dont brake too much. drop to the gears to slow down, save your brakes.
-your rear view mirror is your friend. give way to faster cars. nobody likes a road hog.
@Apr 7 2005, 01:08
[/b][/quote]
woah serious ar? how does that happen? that means i shud change my throttle cable and clutch cable b4 going?
wow.. throttle cable melted? Now thats scary.. maybe i should get
a brand new throttle cable before drift session...
