How To Diy A Micro Compressor?
Lan Dugong
I would like to DIY my own micro compressor. i heard a few of you guys here successfully built one. can anybody help me on this?
thanks
First you DIY Money..
Then you Buy MicroCompressor loh.. :) hahah
I DIY PCV air Injectors.
Items :
- Home Cooking Gas Pipe
- T-Joint
- Air Controller Valve
- Small Air Filter (For Motor Bike / Breather)
- Cable Ties
Step :
- Locate PCV pipe
- Cut and add in T-Joint
- Extend the T-Join to Controller Valve
- Add Breather to the end of controller valve
- Cable tie tighly all the JOINTs
Tuning :
- Make sure all joints are tight.
- CLOSE the air controller valve
- Start engine (Idling Steady/Normal)
- Slowly open the valve..
- Engine starts to die.
- Tune it until the engine is stable again, at the same time got air suck in from the controller.
- DONE.
Forgot to add.. Drink 100 Plus..
NOTE : Mine, I replace the Air Breather with Whistle for 'Secret Mod'.. Thanks.
Originally posted by P_driver@Apr 8 2004, 01:45 PM
Johnson whats the theory behind this 'micro- compressor' thing. Quite curius about how it works. Thanks
to suck in more positive+ air and discharge negative- air for better combustion...i think
Originally posted by WAJA2003@Apr 8 2004, 09:35 PM
That MicroCompressor website no work larr.
If wira 1.3 carb where is the vacum hose??
My friend did lasttime after seeing another of my friend car got . It's car Air Power. I think work the same as Air Compressor.
Original Air Power was sold at RM160 per piece. This only cost RM4 from kedai ikan :lol:
PCV Valve..
It is on the right side if I am not wrong.
G88,
Yeah.. Your lagendary Air Power...
GOOD !!!
Originally posted by noir@Apr 9 2004, 03:22 PM
JL, the whistling thingy for ur PCV, stim ar? Bunyi macam itu BOV ar?
Ada lah sikit sikit.. :)
Siok shiok when changing gear, the pressure will reverse.. then can hear.. PPPSSsstt... (very soft)..
haha u guys... i still dont quite understand how to DIY this thing..
what i need? =p
got so many tubes which looks like a vacumm..err.. which wan to connect..? and also err.. what is that thing? hehe... =p
who is going for the sunway DIY session? hmm...
and also gonna DIY this injector? please please please help me buy the stuffs for it? i cant find those stuffs ler.
now i'm looking for the grounding cables also sakit kepala liaos. sigh...
My compresser is fix aready the cost is RM30
hose,valve,T-join=RM15 take from JL
small fillter brand SIMOTA need RM15
DIY time 20minit,but the engine very very hot
But the effect donno yet,how about the FC??
I only heard the sound only,power ++++,donno also,but i feel when changing gear is more smooth aready.
So let talk how about u MC performance??
