how to alter the pcd??
i_Ce
hello sifu sifu out there..i have the topic to discuss about..is it possible to mod ur pcd? if it is? how and where and of course how much? is it safe? would the rims have a higher chance of cracking? could we just just get spacer to change it? if it's possible? thank you!!:beer:
err....is quite a big hassle to mod ur pcd...just get some rim with 8 holes will do.y so troublesome lerr
Ntg is impossibe..but i believe it ain't cheap and easy
there have 2 ways to mod ur PCD.
1st, get the PCD converter spacer. ( will cost u a few hundred )
2nd, direct change on ur car PCD.
hope can help.
escaflowne ; why do i need to get the rims with 8 holes one? is it different than 4 hole one?
boyzone ; where can i get the convertor? how does it work? is there any bad effect in con verting like that?
thnx
rims 8 holes usually have 2 pcd. 100 (wira, honda,toyota), 114.3 (waja/gen2/iswara).
do check the rim pcd tho. sometimes got same pcd even 8 holes.
i_Ce said:
the pcd is 110 correct skywalker..but what about offset? what does it affect?
offset is a measurement from wheel hub to the wheel arch.... means it determines how much the wheel protrude from the wheel arch or how much it is inside the wheel arch...
optimum offset for kancil, i not sure...:confused_smile:
ok, thnx anyway skywalker..will go around checking rims..by the way, do u know any sparco rims that can fit in kancil? coz i really love sparco rims..
have a read here.
http://www.carbibles.com/tyre_bible.html
and others useful information.
http://www.chris-longhurst.com/carbibles/index.html
batu caves there.. sure you can find the rims you wants that can fit into the kancil size.. offset wise.. like boyzone says.. a good spaccer willg ive you no problem, just invest more for good.. ^^
