wha3536 Known Member Senior Member Jul 22, 2009 #21 Aku baru Beli kereta lantis dah dapat spec cam ni : B8 180 conrod piston JE forged piston Management haltech 550 injectors Turbo gt35 Mintak tlg kawan2 bagi pendapat Ingat hari sabtu ni nak p dyno Tak tahu lak nak up boost berapa?
ZeroDet Known Member Senior Member Jul 22, 2009 #22 fuhhh haltech. JE piston... skrg standard boost brape?? boleh start from 1 bar... Last edited: Jul 22, 2009
lozo 500 RPM Senior Member Jul 25, 2009 #24 i've seen 180 engine with 210 turbo producing 300+ hp. to me, its not the boost that we should concern, it is knock that destroy the engine
K karuuna Sep 12, 2009 #25 waaa ... how to remove boost cut huh ...... anyone can tolong me i am using b8 180
JarsOfClay Known Member Senior Member Sep 12, 2009 #26 boost cut cant b removed but u can bypass it...cheap solution is getting a safc or any other piggy back computers...
waikiki 500 RPM Senior Member Oct 4, 2009 #27 HEy all.. Would like to know wat is the cheapest way to remove boost and speed cut for a B6T ? CHeers to all..
pencalat 500 RPM Senior Member Oct 5, 2009 #28 waikiki said: hey all.. Would like to know wat is the cheapest way to remove boost and speed cut for a b6t ? Cheers to all.. Click to expand... how much cheapest way u want?? If easiest way u can bought used safc lorr.....
R rajie 1,000 RPM Senior Member Oct 5, 2009 #29 i think safc, fuel regulator, walbro, vr4 injectors metal gasket can boost higher already......just put a td05 and boost 1.5bar and see the B6T fly or use VJ23
T timrizal Active Member Senior Member Oct 23, 2009 #30 it seem it you pics there like Lantis engine in an astinaYou did BOT ke?What's your BOT specs?
waikiki 500 RPM Senior Member Dec 17, 2009 #31 Hi Pencalat and Rajie, Thanks for your advice as im still a noobie in regards to Mazda knowledge.
M manong Known Member Senior Member Dec 20, 2009 #32 waikiki said: HEy all.. Would like to know wat is the cheapest way to remove boost and speed cut for a B6T ? CHeers to all.. Click to expand... ' bro ..how bout "aquarium fish bone"?...its work!
