I have install walbro fuel pump and sard large fuel regulator lately,b4 tis my speed can goes up to over 250km/h,but after that 5th gear around 6000rpm,i think is rpm cut already but the speed jz around 22xkm/h,how come?
too much/less fuel?..
what's ur fuel pressure reading???
after install, got do anything for the ECU or not?
Hi Evolution 9682,
mind to share wat is yr stock ecu max boosting? Mine is stock ecu as well but no matter how i set my boost pressure to 1.2bar but the max out put is still 1bar.
Im on Evo 4.
no,i on standard ecu but i have a power fc d-jetro on hand nw,still wan install some otherparts and will go tuning..i think not connected with the ecu since i can go up 250km/h b4...rite?
bro mind to ask mine is e7 with some minor mod ( filter, header, wastegate ) and my boost just can go until 1bar and when it reach 1bar it sound like misfiring and the boost cant go up anymore, im on standard ecu, is there any problem with my ecu? does ecu got related to acd unit oso? i try b4 e-manage and problem same with my boost and one more problem occur that is my acd light all blink, now i have taken out the e-manage but all acd light still on. pls help...
