Honda performance parts
HanJackaL
Following items are for sale, items are in very good condition, they are either used for less than 1 month, or totally unused.
1)Tuned Chip P72 for B18C - RM1200
  • Speed cut removed
  • Rev Cut removed (Can rev past 9500 RPM)
  • Ignition timing Improved
  • Almost perfect Air/Fuel Ratio
  • BIG improvement for B18C
  • Car because much more responsive
  • Power curve increase ALOT when vtec engage
  • Can demonstrate power using my car
  • When used with Piggyback,its same as stand alone ECU
  • Better car idling
  • I gained 12 HP on wheels
  • Chip tuned by my Japanese friend (Agawa san)who is a master of Vtecs.He been tuning Vtecs for more than 10 years.
2)NGK G-Power Spark Plugs for B series - RM50 for 4 (used for 1 month)
3)B16A Fuel Injectors - RM200
4)B18C Type R injectors - RM350
5)B18C GSR Piston Set - RM350
6)B18C GSR Valve set - RM320
7)Civic 97 Spec Rear boot with Red/White semi Smoked tail lights - RM400
P. S : Do check out my wide variety of high quality Stainless steel jewelry for men and women.Makes excellent gifts and is good for your body.
http://www.zerotohundred.com/newforums/showthread.php?t=85106
*Please PM me with which item you are interested in. Have picture upon request..
*Serious buyers can call 012-2357991
*All item prices are negotiable
*Goods sold are not refundable
*Location is PJ area such as Taman Tun,Uptown,SS2,Damansara,Sunway and such.For KL,might be able to travel to Bangsar,Pusat bandar,brickfields
rite... i'm driving a living example. dc2 SiR-G. confirm v-tec. only hp difference and intake manifold and cams. easy to say, the top end is different. block all almost the same. gearbox also almost same ratio as b16a =)
so the head same as b16a or got different??
can fix into b16a??
if can,any different after install the b18c head into b16ablock??
sry.. noob here.. hehe.
can fix into b16a??
No problems.Since both are double overhead cam,and if B18C can fit B16B head,i dont think there will be any problems.Performance will increase if you are using B18C head on B16A block because of 1.8 cams and also higher CC injectors.But if you want to use the B18C head,u will need to change your throttle body and manifold also.I have the whole set for sale at only RM500.
intrested party here...Complete B18C GSR Head including camshafts,Valves,Valve springs and valve retainers+ THrottle body + Intake Manifold (with map sensors)+ metal head gasket... item still in good condition right .. pm me ur best price plz...where is item btw..?? thanx bro for ur time..
chris2000 said:
270cc injectors..
What injectors are these? OEM or aftermarket??
Can fit B18C?
OEM injectors bro...and yes it can fit into B18C.As a matter of fact,they ARE b18c injectors ;)
Yes its plug and play.I bought it for a very high price at japan when i was there for ice skiing holiday.PM me your best price =)
